Electrical / speedometer / tach warning lights
The 2nd time said functioning as designed, not sure don't quote.
3rd time they said it, couldn't duplicate, it doesn't do it consistent enough to diagnose. I mentioned previously there was a service bulletin, fell on deaf ears. Today, THANKS to a post on here, I took the service bulletin number in. All of a sudden they are aware of the problem & it will be looked into and or parts ordered. We'll see.
Code said "intermittent low speed LAN circuit. Was diagnosed after 5 hours in shop on 11-18-11. Said new ignition ordered, would be in on Monday & installed 11-21. Took over an extra week for some reason, didn't call that car was ready 11-30. Will post if any change. Thanks for everyone's help.
I had the exact same symptoms two times in one day a few weeks ago, so I decided that wasn't the car to take to the airport and leave sitting for 2.5 weeks. We got home yesterday and it worked fine today, but I think the IP lights are not working.
Okay, the problem seems to be addressed in TSB #PIP4549A
https://www.chevyhhr.net/forums/show...0&postcount=27
I went out and wiggled the wires around in the area shown in the photo in the post linked above, and although I couldn't see where any wires had rubbed through (I couldn't see well at all), I turned the key on and the IP lights came back on. Seems pretty clear that this is the problem.
plovell66
08-04-2016 07:07 PM
