Emissions Test OBDII
Old Nov 24, 2021 | 08:25 AM
The EVAP not passed could indicate a faulty under hood valve or under car vent valve.
Old Nov 24, 2021 | 10:51 AM
You could try aa different app, there are lots of free ones. Torque (free) is the one I'm familiar with, it may not be available for iOS.
Old Nov 24, 2021 | 07:34 PM
Squibt's Avatar
Thanx for the input. CEL light comes on when key engaged and off when started. No CEL when driving or codes reported. I did add a second battery a few days ago and the car gets very little use….maybe 1 day I drive 10 mins +10 mins back. I will look at the info using Torque also. It may be the vehicle was not driven far/long enough…10 mins is not a lot.
Old Jul 6, 2022 | 11:56 PM
Bonez's Avatar
Originally Posted by donbrew
Your scanner has a graph labelled "H2O", I don't know what that means. After you clear the codes it takes a while before all of the tests run. The O2 sensor data looks fine.
Hydrocarbon ?
Old Jul 7, 2022 | 12:22 PM
greg8453's Avatar
Originally Posted by Bonez
Hydrocarbon ?
Goofy scan tool. Likely means HEATED O2 sensor
Old Jul 8, 2022 | 12:53 AM
PulpFriction's Avatar
Very commonly AKA HO2S.
Obvious typo, or autocorrect doing its finest work. Should have said
HO2 Sensor mV
not
H2O Sensor mV
Raduque
Jul 23, 2020 08:56 PM
John Goelz
May 3, 2020 08:41 PM
alexrckid
Mar 22, 2015 07:28 PM
