Engine continues running when key switched off
Old Mar 14, 2012 | 07:50 AM
Rich7553's Avatar
This just started happening on my '08 HHR LS. Twice yesterday, I made short stops at a couple of stores. After shifting the transmission to park, I turned the key to the off position and removed it. All dash gauges zeroed, as normal, but the engine contined to run for several seconds before shutting down. I've had many vehicles that refused to start, but this is the first one that refused to shut down!
Any ideas?
Old Mar 14, 2012 | 08:35 AM
db/sb's Avatar
That could be a bad rectifier in the alternator. Never had it happen on the HHR but the last vehicle I had that problem with; that's what it turned out to be.
Old Mar 14, 2012 | 08:41 AM
Are you sure it's running as opposed to "dieseling"... How are your temps?
Old Mar 14, 2012 | 10:46 AM
db/sb's Avatar
I was going to ask that....
Old Mar 14, 2012 | 02:28 PM
Rich7553's Avatar
Oh, I feel like a fool! The engine isn't running, it's the cooling fan which has thrown at least one blade and is out of balance. I noticed my temp was running high and did some investigative work. Guess I should have done that prior to posting.
Old Mar 14, 2012 | 06:03 PM
Don't feel bad Rich, my theory is that everyone is allowed one "Homer" every 10 days, but I would change out that fan soon, the vibration from the missing blade will eventually kill the motor and leave you fan-less at the worst possible time....think 110 degrees and stuck in a traffic jam.
Old Mar 14, 2012 | 11:53 PM
Rich7553's Avatar
Note to self: An unbalanced cooling fan is louder than a 2.2L engine at idle!
Old Mar 15, 2012 | 12:07 AM
"my theory is that everyone is allowed one "Homer" every 10 days"
Doh !!! That leaves me out..
seriously: Rich, be glad that you figured it out, without paying the dealer...
Toyoyoye
Jul 19, 2019 07:50 AM
pitbull76
52
Nov 22, 2013 06:02 PM
HHRfrustrated09
Mar 31, 2012 08:05 AM
anichols
Jul 29, 2011 12:24 AM
jmarines
Feb 17, 2009 11:43 PM
