Evap System Frustration
Old May 29, 2017 | 10:08 AM
Don. You stated that Mitchell does not list P0455 but the OP, GIJOE1980 said his code was P0445
Not sure if the OP misprinted or his reader was in error.
Anyhow. Pulled this short list from one of ChevyMgr's old threads.(no P0445 here)
P0420 Catalyst System Low Efficiency
P0442 Evaporative Emissions (EVAP) System Small Leak Detected
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
P0446 Evaporative Emissions (EVAP) Vent System Performance
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0450 Fuel Tank Pressure (FTP) Sensor Circuit
P0451 Fuel Tank Pressure (FTP) Sensor Performance
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
P0455 Evaporative Emission (EVAP) System Large Leak
P0458 Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage
P0459 Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage
Old May 29, 2017 | 10:15 AM
Fat fingers combined with dyslexia! I fixed it.
Old May 29, 2017 | 08:21 PM
GIJOE1980's Avatar
Originally Posted by donbrew
This is odd; Mitchell does not list P0445. But the web shows this:
https://www.obd-codes.com/p0445
If it is really P0443 it is the purge valve (under the hood)
The PCM/ECM monitors the voltage to the purge control valve and has detected a lower voltage than expected. It is a PWM circuit, not on/off.
Sometimes the ABS light will illuminate because the T/C is turned off.
Here is the VOM testing data for both valves:
Attachment 21751
Sorry, the code read out was p0455. Cleaned off the connections and reset codes. After about 4 hours of driving, both CEL came back on and p0455. Any other Ideas?
Old May 29, 2017 | 09:59 PM
P0455 is large EVAP leak. Frequently a bad gas cap, or the O-ring between the valve and the charcoal canister is bad or the valve is stuck open.
https://www.obd-codes.com/p0455
Old May 30, 2017 | 09:59 AM
aradmahogany's Avatar
Luckily the EVAP system really doesn't effect performance of the power train, so you can safely chug along until you get it fixed. The only issue that leaving a check engine light on presents in this case is that you will not be notified if a new, potentially serious, problem pops up. I recommend fixing asap, but know that the code indicates an issue that you can "just live with."
jdieter
Maintenance and Upkeep
27
Nov 16, 2024 10:26 AM
CDS31MC
Mar 24, 2023 09:00 PM
Zagohhr
Oct 22, 2010 07:54 AM
i like!
Tires & Wheels
27
Jan 11, 2010 01:56 PM
Krejaton
Oct 9, 2006 08:03 AM
