Fan noise (vent/AC, not engine)
Old Sep 12, 2011 | 06:48 PM
"I've seen people fall into the void after suffering the injuries you have."
So that's where I am..... I was wondering. (Degenerated disc...... was 3, now 5. Losing other useful joints in my body too)
Anyways back to the blower motor...... It's a "cut out to replace" motor and the only way to get the flange to put it back together is to buy the new "kit" from GM (motor and flange)..... Going used is not an option here, in case you were thinking that route.
Old Sep 12, 2011 | 06:52 PM
chevyorange's Avatar
Oh I've seen people fall into the void after my injuries and less. I didn't mean to imply that was your destination, quite the opposite.
It seems you have passion and interests and those alone are enough, amongst many other qualities.
I hope that didn't sound judgmental, it was not intended.
Thanks for tip on no junkyard blowers. Looks like 200 give or take new.
Old Sep 12, 2011 | 07:01 PM
I wasn't being defensive...... Just trying to "laugh at myself" a bit. People that have never lived with chronic pain just don't quite understand "The Void" (quite an accurate name for it actually)
Old Sep 12, 2011 | 08:06 PM
Originally Posted by 843de
Its a 7 on my scale because of my bad back, once you break your back, the allure of being upside down under a dashboard losses all of its appeal.
Here's a pic of the engine that is in the van now, its a 180 hp Corvair Corsa Turbo engine that I stripped down and had bored .30 over, that along with a billet stroker crankshaft bumped the engine from 164 cubic inches to 198 cubic inches(3.2L for you metric folks). The turbo is a unit made by Rajay for Corvair retrofits, its blowing into two Rochester RV-X carbs with 10 pounds of boost. The two large chrome tubes in the pic that lead off to the right are going into a modified Saab intercooler located in the right rear wheel well, its also running an electronic boost controller with an Air Research waste gate. All this adds up to 292 hp on the dyno, its quite the step up from the 140 cubic inch 95 horsepower engine that I pulled out of the van. Now its not done enough to drive for more than quick test hops, the additional power is overwhelming the rear suspension and giving me some headaches.
Still have lots to do, like fabricating a new engine cover, converting the rear suspension to one from a 1965 Corvair, upgrading to disc brakes all around, and a few dozen other things.
This one looks like I would need a map to check the oil, However I suspect it would please the crowd when it pulls the front tires off the ground. Nice toy 843. I have always wondered with 3 HHR's none SS, you already have a turbo project. Makes sense now.
Old Sep 12, 2011 | 08:07 PM
Cool. I wasn’t specific but it was about 10 years for me and I’m not sure I’m out of the void yet... but your project is inspirational and shows me, for one, that you’re not lost!!
Keep up the work, I aspire to you.
Old Sep 12, 2011 | 10:41 PM
Gee, chevyorange, I've never been called inspirational...a few other things that'll get me banned if I repeat them, but never inspirational. I do what I can do, this van project started in January and I figure it might be another solid year before I'm ready to call it done. Your description of chronic pain as a "void" is very apt, it would be easy to lie down and let life pass me by, but I can't do that. And I admire folks like you and Greybeard who stay away from the void and live life to its fullest no matter what is thrown in your path.
I have 60+ employees who depend on me for their income, a beautiful and wonderful wife who needs me, and so many amazing friends like the folks here...Things like that keep me out of the void.
By the way Sam, it does pop the front wheels off the ground quite nicely thank you!
Its the landings that are troublesome and a bit touchy.
Old Sep 13, 2011 | 05:15 AM
Put some Wheelie bars on that Corvair! That would be neat.
Old Mar 16, 2013 | 11:21 AM
Racer56's Avatar
I believe my issue is that there is debris caught in the blower motor. How do I remove the debris without removing the motor?
Note: I did replace the cabin filter and that's when I think the debris fell into the motor. Please help!
Old Mar 16, 2013 | 12:28 PM
Pull the cabin filter back out and fish around to pull/vacuum the debris out, that is the only access point.
Old Mar 16, 2013 | 12:39 PM
Racer56's Avatar
How do I clean the debris from blower motor?
