flashing engine light
Old Jun 26, 2017 | 11:26 PM
wilborgphhr's Avatar
misfire
Can a bad ecm cause a miss fire
Old Jun 26, 2017 | 11:51 PM
Engine light flashing then it stops but code is still thr wat r the dangers of a flashing lite n causes is it excessive fuel dumping
Old Jun 27, 2017 | 12:14 AM
Using full words really would make it a lot easier to figure out what you are asking.
I interpret your post to mean:
- the engine light was flashing, but stopped
- you want to know if the flashing CEL indicates unburned fuel (ie: the misfire you posted in a second thread - it will be moved to merge with this one when I get to it)
Yes, typically the flashing CEL indicates that one should shut off the vehicle, as unburnt fuel can ruin the catalytic convertor.
Posting the code(s) from the CEL would be a good idea if you are looking for some advice on what to start checking.
Old Jun 27, 2017 | 12:15 AM
That usually means misfiring. If rich, it could damage the catalytic converter. What is the code? Just the code, not the description.
Old Jun 27, 2017 | 12:17 AM
and the original question - can a bad ecm cause a misfire - yup, and so can a whole list of other items.
Without those codes being posted - anything is a total guess.
Old Jun 27, 2017 | 12:41 AM
po304 flashing
Flashin po304 code flashes on n off is this excessive fuel dumping
Old Jun 27, 2017 | 01:15 AM
note that it is p0304 (the last 4 characters are numeric)
P0304 indicates a misfire on cylinder #4 - if that is the only code received and the CEL is flashing, yes it can indicate excess unburnt fuel, meaning what? Bad plug, bad coil, bad wiring to coil, bad fuel injector etc. etc.
Graywolf54#
Nov 25, 2012 06:36 PM
treecem
Feb 1, 2012 09:58 PM
menance
Dec 22, 2010 06:14 PM
catdaddy137
Jul 12, 2009 09:28 PM
