Front end clunking on a 2007 chevy hhr
Old Aug 12, 2018 | 05:46 PM
dogg531's Avatar
This is what i found out today, wife's hht had a noise when hitting bumps or turning, complete inspection of the front suspension found that the lowe control arm rear bushings were wiped out, replaced both control arms problem solved
Old Aug 12, 2018 | 05:59 PM
You would be very smart to change your user name. By publishing your email you give the guys in the internet cafe in Namibia permission to use it.
Scroll down to the bottom of a page click on "Contact Us" There is an option to change it.
Old Aug 12, 2018 | 07:41 PM
Thank you for signing up, glad to see you’re HHR is fixed !
Old Aug 13, 2018 | 09:36 AM
Welcome!!!
Glad you got it resolved. Keep in mind that the other common noise problems in the front end are caused by: the sway bar links (ball joints wear out and get sloppy), the sway bar bushings that hold it down to the frame.
DaveB
16
Dec 18, 2010 10:11 AM
DanH
Oct 5, 2010 01:41 PM
whiteyHHR
Jun 19, 2010 01:44 PM
3amigos
Jan 8, 2009 09:50 PM
HHR-VTX
Jan 7, 2009 10:58 AM
