Front end clunky noise
Old Feb 21, 2013 | 04:29 PM
badassbowtie's Avatar
A arm bushings(lower control arm) are another part that is known to wear out and cause a front end noise.
X2!!!!!
this is the most common "clunk" in the delta platform...
Old Feb 26, 2013 | 10:59 AM
Beaglelover's Avatar
Good report .... so far!
Pleased to report that as of right now the replacement of the front swaybar bushings has eliminated the clunking noise. I took the HHR to a suspension/transmission specialist to cut to the chase. He charged me $117.00 to replace all the bushings. I was pleased with that figure because first he had quoted me around $200.00. He did say the dealer had shipped him the wrong size bushings .... be sure to get the right size and take it to someone who knows their trade. Now, I'm trying to get the dealer who sold us the vehicle to reimburse us for the repair. This was an issue that the dealer's shop should have picked up on if they had the HHR up on the rack at all.
Old Feb 26, 2013 | 04:37 PM
Rod Run's Avatar
Originally Posted by MCHHR
I'm chiming in my $.02 here as I fought this problem for a few years from 30k until 110k miles. A Chevy mechanic had told me this is a common problem and they have to change parts until the noise goes away. Here's what we did in order:
1. Replaced all 4 struts including mount hardware/bump stops and sway bar end links (or so I thought)....noise still existed
2. Replaced lower control arm vertical bushings....noise still existed
3. Replaced sway bar bushings that run under the car....noise still existed
4. While working on driver side with tire off, noticed the sway bar end link was still factory. Mechanic didn't replace it, just the passenger side. Visually it seemed ok, but upon further inspection when trying to remove it, the 17mm nuts attached to the threaded bolt were worn down to no chance of getting a wrench on them to remove. Was able to vice grip and remove the outside nut...took a long time. Slapped on a moog with grease zerks....noise GONE!!!(.
If I may chime in with my $.02 here..... I suggest you get a new mechanic. For a "mechanic" to change 3 different things, for a simple clunking noise, without ever actually diagnosing and seeing the actual problem causing component, he needs to go
When I fix a car, I never just start throwing parts at it, without seeing and troubleshooting that actual condition. Any idiot can keep changing part after part, because sooner or later (usually later), he's going to get it right. Then he will claim that he fixed it
Old Jun 24, 2013 | 01:46 PM
catcrys97's Avatar
Originally Posted by F-16C
Your front bumper cover could be loose. Grab it and try to move it up and down. Mine was loose and I tighted it up. much better.
So, could you tell me how to go about tightening up the front bumper cover on my '07? Maybe point me in the direction of another forum post that describes the process? The upper half feels relatively solid, but the lower half is terribly loose. I climbed under there and saw a bunch of clips & black plastic shields in the way. Hate to waste the time taking all of that off if I don't have what I need to tighten it back up.
Pretty sure this is the source of my clunking noise. Result of incompetent good samaritan who *tried* to help my 16 year old daughter change a front tire. Instead, he placed the jack behind the tire he was changing, which then fell. (If only he had listened to my daughter when she told him where to put the jack!) When we arrived, he was gone and the front of our car was on the ground in the ditch... And he dented the hood when placing the tire on the roof... Did I mention he used to date my daughter?? Oh wait, I digress...
Any help would be appreciated!
Old Jun 24, 2013 | 07:00 PM
Fox Hat's Avatar
Is that a new record for time between joining and a first post lol
Old Jun 24, 2013 | 09:18 PM
  #26
catcrys97's Avatar
Haha! I've used this site to find the answers to lots of questions. This is just the first time I've had to ask for help!
So, any ideas on how to fix the damage done by a 16 year old who was trying to impress the girls yet did everything wrong?? *sigh*
Old Jun 25, 2013 | 04:42 AM
  #27
Problem is, it's not going to be just a matter of "tightening up the front bumper cover".
You seem to have some type of damage, thanks to the 16 year old. You're going to have to find out exactly what he damaged under there.
All those plastic clips and screws that hold the cover on have matching holes that they line up with. I'll bet some have pulled loose or out, or even broken.
It's just going be a, "Jack it up and get under there and see what's wrong."
Old Jun 25, 2013 | 04:43 PM
  #28
axebuilder's Avatar
I have had the clunk noise for a while...nd started to embrace it lol.
Thanks for the link on fixing, something I can handle and will fix.
Old Jul 18, 2013 | 07:04 AM
  #29
catcrys97's Avatar
Woo hoo! Problem solved! Combination of loose bumper (replaced a bunch of clips & added a couple screws) and messed up sway bar links. Car sure sounds a lot better now!
Old Jul 18, 2013 | 12:13 PM
  #30
Awesome another thread to put to bed!!!
Lee3333
Mar 2, 2015 07:47 AM
bal07hhr
Jun 20, 2014 04:33 PM
fsc44
Aug 29, 2012 02:11 PM
66Vair
11
Sep 4, 2010 09:15 AM
HHR321
Feb 17, 2007 11:18 AM
