Front Rotors Needed To Be Cut at 6000 miles
Old Nov 23, 2006 | 11:40 AM
  #31
burbhhr's Avatar
auto transmission
automatic transmission... I'm 1LT, wonder if your 2LT with better sway action relieves some brake stress on winding mountain roads... who the heck knows.
Old Nov 23, 2006 | 12:53 PM
  #32
burbhhr's Avatar
mountain problem only...so far
Keep in mind, I've only experienced this when I come back down the mountain (so far)... never on the open road or highway, city driving etc.
Old Nov 23, 2006 | 01:24 PM
  #33
Black Beauty's Avatar
My front left seems to be the squeaker too.
Old Nov 23, 2006 | 01:44 PM
  #34
JuMPy's Avatar
I didn't see this thread when I made mine ....... so I guess I'm not the only one...... I guess a call into GM is in order, although I suspect not much will come of it
Old Nov 23, 2006 | 04:20 PM
  #35
oneton's Avatar
I have a LS base model, 2.2L eng., auto trans, with full moon hubcap. [that they tell me will make my brakes run hot]? 27,000+ miles, no noise, no shake,
I rotate tires at 3000 with a 1/2" drive air gun, Pads are still better then
50% never turned rotors. I don't even turn rotors if & when I install new pads. I drive fast, brake late, Of all my GM cars/trucks never any noise or shake. Just very lucky I guess !
Old Nov 23, 2006 | 04:31 PM
  #36
Z-Man's Avatar
Originally Posted by DDock
Had to share this one with the forum. I've been driving new vehicles for some time. Recently my 2006 HHR (6000 miles) starting vibrating terribly when braking. Took it to the Chevy dealer and they told me that my rotors needed to be cut. At 6000 miles! They cut the rotors and now the car is functioning like new. Just wondering if anyone else has had this experience with their HHR. Hope this won't be happening on the regular. Any suggestions if it does happen again?
I know of at lease 5 HHr owners who had their Rotors turned , Cut or replaced. they replaced mine at 23.000 miles for free. Good luck!
Old Nov 23, 2006 | 06:08 PM
  #37
Yeah, Oneton, don`t gloat though, you`ll had you bad spot sooner or later.
Old Sep 28, 2007 | 02:27 PM
  #38
DDock's Avatar
Hi, I'm now around 20,000 thousand mile on my HHR (2006). Having to have my rotors resurfaced/cut for the third time. I tried to get the service manager to just give me new rotors but he said that GM would not approve it. I think I just happened to have a bad set of rotors from the start. Any suggestions on what I should do? I'm sure I will need them resurfaced again in 6000 thousand mile. They will still be under warrenty, but it's just a hassle. Any thoughts?
Old Sep 28, 2007 | 02:47 PM
  #39
Snoopy's Avatar
You might want to read this post that I started.
https://www.chevyhhr.net/forums/show...ght=shuttering
Mating machined surfaces need to be cleaned very well, according to what I was told by GM Engineering. This assures the surfaces match exactly as intended.....the photos in the above link will demonstrate this. Most of the dealers are NOT performing this service step when servicing the brakes. You may wish to pull a wheel and see what the appearance demonstrates. DON"T FORGET TO RETORQUE THE WHEELS TO THE 100 FT/# as recommended by GM. Anything less or more causes additional problems.
Oh, and forgot to say...tire services center, dealers and car owners are NOT doing this either, when they do TIRE ROTATIONS. It needs to be done WHENEVER a wheel is removed from the hub.
Good Luck.
Old Sep 30, 2007 | 05:41 PM
  #40
haypops's Avatar
Originally Posted by burbhhr
Hey all... coming home from Big Bear Lake Sunday night and going down the mountain experienced terrible vibration and rattling from front left brake. Pretty scary stuff when traveling down a mountain road in the dark!! .
I came down the front way (Rt.18 from Lake Arrowhead). I put the transmission in I and came down the hill with little or no braking or high revs.
