Fuel gauge issue
Old Jul 26, 2011 | 09:58 AM
LawDog88's Avatar
Maybe a bad fuel pump assy. I had a 2000 silverado, pump worked fine. needle wouldn't. replace it, worked fine since. this happened a few years ago. truck was about 6yrs old then.
Old Jul 26, 2011 | 10:09 AM
Snoopy's Avatar
I'm going in the direction of Greybeard's logic.....
Did you top off the take......squeeze the last penny of gas into the tank.... You may have damaged the charcoal filter.
Old Aug 3, 2011 | 10:57 AM
Me and my monkee's Avatar
Got the codes read at Autozone
In fact there were two codes, P0461 and P0463
Printouts for both codes were the same
Definition: Fuel level sending unit condition
Explanation: Poor electrical connection at the fuel level sending unit
Probable Cause: Failed fuel sending unit
Thanks for the help so far, but now what?
Old Aug 3, 2011 | 11:04 AM
Well its either a bad sending unit, or a loose/corroded connector at the sending unit. In either case the fuel tank needs to be dropped, not the worst job ever, but one that is a pain in the butt regardless.
Here's an excellent write up on replacing the fuel pump by BeanWagon, it'll show you the location of the connectors on the fuel pump. You may find that changing the entire pump/sending unit is the only and best option.
https://www.chevyhhr.net/forums/how-tutorial-library-21/fuel-pump-replacement-36541/
emstess
Oct 10, 2021 12:23 PM
cop272471
Oct 2, 2014 04:56 PM
Galaxie500XL
Mar 19, 2013 02:16 PM
geg
Feb 28, 2011 06:18 AM
