Is the fuel pump bad when it .......
Old Apr 24, 2015 | 12:34 PM
Ijazzu's Avatar
I still have my old fuel pump & I will look for the check valve. It sounds correct. If the valve is something can replace, I will do that and keep this pump as a spare.
Thank You!
Old Apr 24, 2015 | 02:28 PM
db/sb's Avatar
Not sure if the check valve can be replaced in the modern day fuel pump 'module'. Back the the day, when I was into Datsuns, I owned a 280z. The symptoms in your thread reminded me of those days. Loss of fuel pressure due to a bad fuel pump check valve was rather common on 280Z and 280ZX's. The difference being that you could just jack those up and change the valve since the fuel pump was on the outside of the fuel tank.
Old Apr 24, 2015 | 02:47 PM
Whichever bit failed, it was still part of the fuel pump assembly.
At least it's fixed now.
I wondered about that 25mm socket!
Old May 5, 2015 | 09:35 AM
Ijazzu's Avatar
Pictures of the fuel pump. I was NOT able to see or find a check valve. Maybe someone can point it out to me?
Old May 5, 2015 | 11:25 AM
db/sb's Avatar
It's likely built in somewhere along the outlet path and not a replaceable part.
Old May 5, 2015 | 01:29 PM
  #26
My guess is it's integral to the pump part. Usually just a flapper of some sort.
Jeda13
Sep 19, 2014 04:42 PM
2007OrangeHHRLT1
Feb 3, 2014 04:45 PM
Mattasticbmx
2.0L Performance Tech
Feb 19, 2013 11:38 PM
BeanWagon
Jul 2, 2011 10:36 PM
Brucet
Maintenance and Upkeep
18
Apr 21, 2011 01:48 AM
