Heater Blend Door Broken
A lot of flat rate hours for the job. And a dealership will only do the exact repair that is in the book. If the book says replace the entire assembly, that's what they Will do.
I would suggest finding an independent shop.
does this sound right my blend door is stuck on cold. heater quit working last spring
well fall is coming so i took it in to a dealer to get it repaired and got knocked out of my socks when i was called with the price of 1500.00 clams and change. was told it was going to take a new heater box to fix. sound about right?
I wonder it the repair kit would work on an hhr.
Possible related problem, my 2008 SS 5sp has started making a loud flapping noise from center dash vent area at higher blower speeds. I pulled bezel around radio to look in vents and can see a gray foam seal, I believe is blend door seal, loose and flapping around. Anyone out there aware of a bulletin covering this issue??
Why would you seek a bulletin?
A simple search turned this up in the "how-to" area.
https://www.chevyhhr.net/forums/how-...nd-door-49574/
