Heater Blend Door Broken
Old Aug 12, 2015 | 02:36 PM
A lot of flat rate hours for the job. And a dealership will only do the exact repair that is in the book. If the book says replace the entire assembly, that's what they Will do.
I would suggest finding an independent shop.
Old Aug 13, 2015 | 12:00 AM
Lucky's Avatar
Originally Posted by davefv92c
does this sound right my blend door is stuck on cold. heater quit working last spring
well fall is coming so i took it in to a dealer to get it repaired and got knocked out of my socks when i was called with the price of 1500.00 clams and change. was told it was going to take a new heater box to fix. sound about right?
Sounds like the temp door broke. They make a repair kit for the equinox.
I wonder it the repair kit would work on an hhr.
Old Jun 15, 2016 | 03:46 PM
sumo1's Avatar
Possible related problem, my 2008 SS 5sp has started making a loud flapping noise from center dash vent area at higher blower speeds. I pulled bezel around radio to look in vents and can see a gray foam seal, I believe is blend door seal, loose and flapping around. Anyone out there aware of a bulletin covering this issue??
Old Jun 15, 2016 | 05:28 PM
Why would you seek a bulletin?
A simple search turned this up in the "how-to" area.
https://www.chevyhhr.net/forums/how-...nd-door-49574/
Old Jun 15, 2016 | 07:11 PM
sumo1's Avatar
thanks donbrew, has there been a problem with these seals becoming loose over time? Also... what kind of time should i alot for fix??
Old Jun 15, 2016 | 07:35 PM
I never heard of it.
I don't think you can see the blend door from the center vents. I don't know for sure.
Old Dec 24, 2021 | 01:12 AM
johnnysalinas7's Avatar
blend door repair kit
Has anyone tired the blend door repair kit on the hhr?
Old Dec 24, 2021 | 07:05 AM
Not to my knowledge, if you do , post a how to and please take photos!
Zala
Sep 9, 2024 07:09 PM
leo pinetree
Jun 7, 2021 11:51 AM
frank kaminski
Feb 19, 2014 07:12 PM
Spade
Sep 16, 2013 05:44 PM
Leonard
May 29, 2012 10:34 AM
