Heater Motor Resistor Question(s)
Old Apr 21, 2023 | 04:44 PM
  #51
No it’s not , have you inspected the back of the HVAC control panel in the water fall under the radio, look for melted or burnt connections
Old Apr 21, 2023 | 04:45 PM
  #52
You might have a look at the back of the speed selector for fried wires.
The cabin air filters do get clogged and soaked if the butyl patch leaked. Nobody ever changes them.
I have no idea what a ground might have to do with overcurrent, other than somebody thinking the switch switches the hot side and splicing into the wire. Or, using that wire for a LED ground.
ALL of those "extra ground" Facebook solutions are junk, don't do it. They can cause your exact problem, If there is a ground problem just fix it.
Old Apr 21, 2023 | 06:36 PM
  #53
Have you inspected or tested your fix on the butyl patch (cowl seal)? Perhaps it started leaking again.
Old Apr 24, 2023 | 05:09 PM
  #54
PulpFriction's Avatar
Chevys have been frying resistor packs for at least 30 years. "Good enough" mentality apparently. This is such a simple system. It could be bulletproof. The resistors can't take the heat as installed. It could be much more reliable with better design and QA.
For sure, if you find yourself with a bad resistor pack a second time, don't buy the same brand.
shep5606
Jan 11, 2023 01:43 PM
Morna
Jan 10, 2020 05:54 PM
Keenan2789
Jan 23, 2016 06:54 PM
Dinky Toy
Feb 16, 2013 12:27 PM
speedemon
Jan 8, 2013 04:12 PM
