Help!!! I need more info ENGINE AND TC LIGHT ON
Old Aug 24, 2014 | 09:16 AM
db/sb's Avatar
Is that a copied and pasted answer from the other thread??
Old Aug 24, 2014 | 09:21 AM
Not according to your quote window db/sb, but close!
Old Aug 24, 2014 | 09:40 AM
db/sb's Avatar
The lower two quotes are in my signature. I meant these two:
Originally Posted by ChevroletCustomerService
Hello sdavis1465,
I understand that you are unhappy with the service you experienced at your local dealership. I do apologize that you are unhappy and for any inconvenience this may have caused you. Feel free to contact us for further assistance.
Jennifer T.
Chevrolet Customer Care
Hello sdavis1465,
Jennifer T.
Same post; two different threads. (I just posted it to the wrong thread)
Old Nov 20, 2014 | 09:14 PM
mzsusyQ's Avatar
I'm back!!!
Hey everyone!! I'm back with the same problem except the code that's pulling now is a p010 I need ya'lls expertise again!! I believe it's been about 2 years if I'm not mistaken since first time I posted about my problem so the fix lasted a bit just need to figure out how to fix this code now!! Any and all info welcomed and appreciated!! <3
Old Nov 20, 2014 | 09:34 PM
Do you mean a P0010 code?
If that's the case, give the following thread a read....
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
You'll note that we've looped right back to whopper's reply in post #5 from 2012.
Old Nov 20, 2014 | 11:21 PM
  #26
mzsusyQ's Avatar
So it's the same thing/part?! just needed to confirm before we buy the parts!! Hubby went to buy them and counter person told him it was only one part that was needed so it confused me since we replaced two in 2012!!
Old Nov 20, 2014 | 11:48 PM
  #27
If it's the p0010 code, you only need the one solenoid - the one for the INTAKE side - you do not need to replace them in pairs, although you may wish to consider doing so rather than face the possibility of tearing apart to replace the other one if it too goes faulty or gets fouled with overdue oil changes etc..
And IMO I'd stick with the genuine GM ones. The part number (GM # 12655420)is at the start of the highlighted thread above: https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Old Nov 20, 2014 | 11:52 PM
  #28
Oh I just read the thread from the start - at that time you replaced the EXHAUST solenoid - so the INTAKE one must be the original - you only replaced the one, not both.
Old Nov 21, 2014 | 12:25 AM
  #29
mzsusyQ's Avatar
Once again Mr. Whopper you are correct!!! Just confirmed with the hubbs and yes only one was replaced so we will be replacing the intake!! Can't thank you enough!!
Old Nov 21, 2014 | 10:06 AM
  #30
No problem - let us know how it goes on the fix.
