Help! Need clarification on coil pack vs timing chain
Old Jun 13, 2018 | 11:37 AM
SweetTrixie74's Avatar
Originally Posted by Oldblue
All the other parts are fine. Did you find you 10 mm socket?
HAha yeah, i got one. I just called the company and they verified this part will work for my car. I made him double and triple check.. Uuugh... and it won’t be here till maybe next Tuesday....
Old Jun 13, 2018 | 12:22 PM
The 2.4L always had "new" tensioner and VVT. At least, on HHR.
Just don't lose the 14mm.
Old Jun 13, 2018 | 12:23 PM
Lol!! Its the 10mm that keeps going awol on me!
Old Jul 2, 2018 | 08:04 PM
P0300 misfire after changing coil pack and spark plugs
Today I changed all 4 spark plugs after getting a P0300 for random misfire. The timing chain was replaced. 2 links were stretched and the tensionor was busted. Today it ran so bad the check engine lights flashed. After changing the spark plugs ( which had oil on them in cylinder 2 and 3 ) it ran better, but still idled rough. Hoping it just needs coil packs, not a dead cylinder or bad valve seat. I did replace one coil pack on cylinder 2. Help! I need to fix this car! Thanks in advance. -Jenni. Ps, i posted about this on the Chevy HHR owners group on fb. Engine is a 2.4 DOC, Ecotech 2.4L.
Old Jul 2, 2018 | 08:40 PM
This post was moved from it's new thread to here - lets keep the whole story in one spot.
And posting what the current are for the check engine light flashing would be a good next step. FYI: the coil packs are not a common failure point, and no, they do not go bad in pairs, or all 4 at once. The problems you are having now might be due to having let it run out of oil at the start of all your problems. So, get the engine error codes and post them here.
Old Jul 2, 2018 | 09:10 PM
  #26
Sorry, im kinda new to the whole forum thing.. Still figuring it out
Old Jul 2, 2018 | 09:28 PM
  #27
I'm hoping that the valves are not bent
Old Jul 2, 2018 | 09:33 PM
  #28
Oil on the plugs is never a good thing.
Old Jul 2, 2018 | 09:54 PM
  #29
So am I!! How would i find that out?!
Old Jul 2, 2018 | 09:55 PM
  #30
NOPE! Definitely not...
