Help...smoking while idling
I got my oil changed a few weeks ago...car went in the shop for body repairs the week I got the oil changed so basically I've driven the car a week since the change. Anyways I noticed mid week that when I took off at a light I had a puff of smoke...hard to tell the color but I'm pretty sure it was bluish which I know is oil. It happened again yesterday again today while idling outside the grocery store waiting on my girlfriend. When I rev the motor a pile of smoke comes out that exhaust. My first thought is the valves but I've got 41k miles...that seems to be short lived for valve guides. I've noticed my gas mileage is not as good right now so I'm wondering if it may be something fuel related as it smeels like a fuel oil mixture. Of course I'm out of my bumper to bumper warranty so I'm hoping it'll be something covered under the drivetrain warranty. Any ideas? I'm planning to drop it off at the dealer tomorrow.
It may be a blown head gasket or cracked head, has it triggered the CEL yet?
The dealer should do a compression check, examine the plugs for oil fouling, possibly a cylinder leakdown test too depending on what the compression check shows.
When you had to abandon it in the snow storm, did you leave the keys in it? Or did the towtruck operator try to "rock" it free from its position in the ditch?
A stuck fuel injector that's washing the oil off the walls of the affected cylinder is also a possibility, how's the idle quality, does it sound like it's missing?
Idles and runs perfect...not running hot...temps are fine. Nothing comes out the exhaust until it sits idling for a period of time then clears up. When I turn off the car and go back out and crank it up...give it a rev nothing there. These definitely some soot buildup around the back bumper where the exhaust is released. No cels...doesn't sound like its missing at all.
I'd suggest checkin' how the spark plugs read, sure sounds like valve guides to me. Idling produces the greatest amount of vacuum. Which (if guides are worn) will suck down oil..
Leak down test (as earlier suggested) can pin point any issue & where.
It's at the dealership this morning...told them I had the oil changed there a few weeks prior and it sat for a week at the body shop. Who knows...I seem to have really bad car luck lol. I'll keep you guys updated.
They are doing an alignment for me since I installed my coilovers over the weekend. Also they are checking to see why my gear shifter sticks on cold mornings (automatic). She said that there were some recalls coming up in April for the gear shift and the ignition for my year model but they'd go ahead and check today.
I have 2 of the 2011 models and had the shifter replaced at approx. 20,000 on the 2LT.
My B to B Warranty runs out next month on the other HHR.
SF
