Here we go again
Old Jan 18, 2019 | 09:42 PM
I showed how easy it is to pop the I/P to check the connector so that you could do it. 4 screws + 4 retainer clips.
There was a TSB for an earlier year about the connector being loopy.
Since ONLY the I/P is involved and there is 1 connector to the I/P doesn't it make sense that the best place to look is the connector? If not at the I/P then at the BCM
OR, fuses 7 & 16 on the BCM could be loose.
Just for good measure here is the connector info.
Old Jan 19, 2019 | 11:52 AM
piper27's Avatar
I'm in the process of of removing the cluster to check the connector. I've run into a snag trying to remove the connector. I can't seem to find the release on the connector, the old eye's aren't what they used to be. Anyone know how to take it apart, and what am I looking for when I get it apart?
Old Jan 19, 2019 | 12:05 PM
Cat Man HHR's Avatar
Take a look at this:
https://www.chevyhhr.net/forums/how-...-custom-32481/
Old Jan 19, 2019 | 12:11 PM
piper27's Avatar
Originally Posted by Cat Man HHR
Could you give a couple of pictures from different angles and try to focus a little better.
Thanks
I figured it out Cat Man, Now wonder what I should be looking for? Everything looks good to me.
Thanks for the link, very helpful
Old Jan 19, 2019 | 02:22 PM
piper27's Avatar
Put it all back together again after plugging and unplugging the connector several times. Started the engine, and everything is working fine for now. I'll let it sit overnight and see then. Usually first thing in the morning it always messes up, so I will see.
Old Jan 19, 2019 | 02:43 PM
  #26
Coulda been dust in the contacts, fingers crossed, you got it fixed.
Old Jan 19, 2019 | 03:44 PM
  #27
piper27's Avatar
Man, I hope so. I'll let you know
Old Jan 19, 2019 | 03:52 PM
  #28
Check those fuses. Get some dielectric grease to put on the connector pins.
Old Jan 20, 2019 | 07:28 AM
  #29
piper27's Avatar
Too late for the die electric grease now, everything's been put back together. I have checked the fuses. wondering if there's a relay for the instrument cluster?
Started it this morning, and it's back to it's old tricks.
Old Jan 20, 2019 | 07:48 AM
  #30
2manyvans's Avatar
I know it's not an HHR but my '99 Jeep Cherokee had the same kind of problem with the cluster gauges . The fix was a new connector plug and pigtail where it went in the back of the cluster. The pins had turned gray. A kind of corrosion on them. I learned about it on U-Tube
