Here we go again
Old Jan 23, 2019 | 10:47 AM
  #31
piper27's Avatar
I still think I have a parasitic drain on my battery. I've checked all the fuses for voltage draw, and they all show 0.00 draw. I'm thinking it might be a bad alternator diode drawing power back from the battery at night. As a test, with my battery fully charged, if I pull the 2 wire connector off the alternator and leave it off overnight, will that stop the draw if it is a bad diode?
Old Jan 23, 2019 | 11:02 AM
  #32
Cat Man HHR's Avatar
How bad of an amperage draw do you think you have ?
Watch this, it might help;
Old Jan 23, 2019 | 11:12 AM
  #33
Have you checked to see what the parasitic CURRENT draw (measured in AMPS (with an ammeter), not voltage) is from the battery when the car is shut off? That will also tell you the difference if/when you disconnect the alternator.
Anything over a 80-100ma is considered unacceptable as per https://www.optimabatteries.com/en-u...parasitic-draw
This video discusses battery/charging system and parasitic draw issues - An explanation on measuring and troubleshooting a parasitic draw issue starts at the 1:20 mark -
and this one from Eric the car guy is pretty good as well, with a little more detail on tracking down a parasitic draw -
Old Jan 23, 2019 | 12:02 PM
  #34
piper27's Avatar
https://www.youtube.com/watch?v=lRcj1fQcWwU
It looks like 140 milliamps/ 0.14 amps. Should I remove relays also to check where the draw is? Actually after 15 or so minutes it went down to 0.00
Old Jan 23, 2019 | 12:11 PM
  #35
piper27's Avatar
Thanks Whopper, I've seen both of them
Old Jan 23, 2019 | 12:21 PM
  #36
The car has retained power.
Old Jan 23, 2019 | 12:41 PM
  #37
Yeah but not enough to drain the battery.
piper 27 you have more than enough info to diagnose your problem.
I would suggest you take it to a qualified repair shop if this is above your mechanical skills.
Old Jan 23, 2019 | 01:52 PM
  #38
I was referring to the "after 15 minutes it drops to 00" part.
Power is retained for the windows, locks, radio, sunroof, head lights, interior lights etc.
Old Jan 23, 2019 | 02:37 PM
  #39
piper27's Avatar
Yeah Cat Man, if I was smart i'd do that, but I just can't throw in the towel yet. I'll keep plugging along for awhile.
Old Jan 23, 2019 | 03:05 PM
  #40
OK then watch the videos and learn.
