Here we go again
Old Jan 23, 2019 | 09:58 PM
  #41
Don is right - the initial current draw is higher for a few minutes then drops back down. However it should not be dropping to ZERO. I suspect your meter is either not accurate, a bad connection, or you have the reading set too high?
If it actually drops below the 50ma range after a few minutes then the problem lays elsewhere - like the battery itself. If the alternator or anything else in the car was causing the problem, then there would be a sizeable current draw.
Old Jan 29, 2019 | 06:03 PM
  #42
piper27's Avatar
Decided to try the obvious, so went to the scrapyard last thursday the 24th and for $30 took a instrument cluster from another 2011 hhr. I put it in mine and haven't had a problem with it since. I'm still going to give it a couple of weeks before I say it's fixed though. I know I still will have to take it someplace to have it programed to read the right odometer reading on my car. The replacement cluster shows 155,544 and mine is about 101,000.
I do want to thank everyone so much that tried to help me with this problem. I'm crossing my fingers and toes that it is fixed. Stay tuned
Nightwalkerhemi
Apr 8, 2014 04:43 PM
RHHRTOYPANEL
Jun 20, 2007 08:31 PM
Lee3333
Mar 24, 2006 10:40 AM
Navyflyer11
Mar 4, 2006 09:11 AM
