Here we go again
I still think I have a parasitic drain on my battery. I've checked all the fuses for voltage draw, and they all show 0.00 draw. I'm thinking it might be a bad alternator diode drawing power back from the battery at night. As a test, with my battery fully charged, if I pull the 2 wire connector off the alternator and leave it off overnight, will that stop the draw if it is a bad diode?
Have you checked to see what the parasitic CURRENT draw (measured in AMPS (with an ammeter), not voltage) is from the battery when the car is shut off? That will also tell you the difference if/when you disconnect the alternator.
Anything over a 80-100ma is considered unacceptable as per https://www.optimabatteries.com/en-u...parasitic-draw
This video discusses battery/charging system and parasitic draw issues - An explanation on measuring and troubleshooting a parasitic draw issue starts at the 1:20 mark -
and this one from Eric the car guy is pretty good as well, with a little more detail on tracking down a parasitic draw -
How bad of an amperage draw do you think you have ?
Watch this, it might help;
https://www.youtube.com/watch?v=lRcj1fQcWwU
I would suggest you take it to a qualified repair shop if this is above your mechanical skills.
Yeah Cat Man, if I was smart i'd do that, but I just can't throw in the towel yet. I'll keep plugging along for awhile.
