HHR front end noise.
Old Apr 24, 2010 | 06:49 PM
hyperv6's Avatar
Originally Posted by Smallblock
At first it was any speed over 45 now its Any time the car is moving. Gets worse with more weight.
Wheel bearing hub is my thought too.
Hub failiure is very common on all makes as they all use very similar ball bearing hubs.
Many are bad long before you hear them.
Most cars today use them because they have less resisitance and add to the MPG. But they do not hold up like the old taper bearings.
There are many new companies that just deal with selling these hubs today since they are in great need.
Many of the brake problems on todays cars are related to bad hubs. Note that most complainets started when the hubs came into use.
Old Apr 24, 2010 | 06:51 PM
jst333's Avatar
Bet its the wheel bearing assm. I just replaced the drivers side, at 69k. It started very subtle and steadily got worse, all in the course of 3 weeks. Would start around 40mph and the noise would sometimes go away at high speed.
Old Apr 24, 2010 | 09:48 PM
Smallblock's Avatar
This is a constant growl/droaning sound
On second thought.....Don't really care if If i get this fixed or not.. it's soon to be my future ex wives Problem. It's her's along with the payment.
Old Apr 25, 2010 | 08:14 AM
rexh62's Avatar
Originally Posted by HHR4JK
i had a clunking sound.... they replaced the struts both sides. which at first no clunkie at all after driving on a short trip 500 miles, and now i have a slight clunk..not as loud.. but it sure does ride better.....clunky but smooth ride.......
Have them check the steering column. I just got mine replaced under warranty as this is a known problem for not only clunking noise while going slowly, but a steering problem.
Old Apr 25, 2010 | 01:09 PM
Don06's Avatar
You're lucky, usually they split everything right down the middle, she gets the car and you get the payments.
arkansashhr
34
Mar 1, 2015 03:11 PM
bal07hhr
Jun 20, 2014 04:33 PM
badandy519
Aug 28, 2013 01:18 AM
fsc44
Aug 29, 2012 02:11 PM
HHR321
Feb 17, 2007 11:18 AM
