HHR LS stuck in anti theft mode
Old Jan 12, 2025 | 06:45 PM
Check connections, starting at the battery. Disconnect and tuck away the negative cable before removing any other cable connections. Terminals clean and tight, clamps not broken.
Then the lug on the side of the underhood fuse block near the front. Clean and tight, should be 2 cables there, from the battery positive and to the starter.
Then the lug on the starter.
Tighten the four 7mm bolts inside the underhood fuse block. These need to be really tight. Seat all fuses and relays securely.
jbindert
Feb 14, 2024 03:33 PM
Allen P
May 25, 2021 04:10 PM
SlickRick2
Dec 16, 2016 04:32 PM
chris082676
Mar 29, 2008 12:59 PM
TX-HHR
Jul 5, 2006 08:03 PM
