HHR won't start
Old Aug 14, 2017 | 11:58 AM
Debra A Vitti's Avatar
HHR won't start
No start no dashboard message no sound wtf i replaced alternator and battery with new parts less than 30 days ago now whats the problem? When i turn the key on no sound but all lights are on sometimes you can hear it trying to start and sometimes it will start help me please 2006 chevy hhr lt 2.4 4 door
Old Aug 14, 2017 | 12:09 PM
J W Davis's Avatar
What you are describing sounds like a fauly ground either on the engine or the body. Double check everything you can see, these little truckets need good reliable source of power to work.
Old Aug 14, 2017 | 01:03 PM
Hi Debra, to the forums!!
It sounds like the battery is dead again. You may have a parasitic drain, or the new battery or alternator has failed. The battery may need the terminals cleaned.
Charge the battery if needed, and have your local auto parts store perform a charging system test. They can charge and test the battery for you if you do not have a charger.
Old Aug 14, 2017 | 01:09 PM
Make sure the large red wire is connected securely to the underhood fuse box.
Moved to a new thread
Old Aug 14, 2017 | 04:23 PM
Welcome to the site.
Based on the info above I'm guessing this is an ongoing issue and not a 1 time occurrence . Like the others have stated, sounds like maybe a bad battery connection somewhere. As Don said, check the main battery cable at the underhood fuse box.
If you're not familiar with automotive electrical stuff, find a friend to help or a good repair place.
Old Aug 20, 2017 | 07:50 PM
Asking to "help me please". 6 days later and the OP hasn't returned.
I wonder why I even bother to answer.
Old Aug 20, 2017 | 08:11 PM
Because you're a first responder, you care to help others, complete strangers !
So you jump in both feet!
That's what makes you , you!!
Goldie6175
Apr 25, 2014 06:37 PM
bluedograbbit2
Jun 1, 2013 11:27 AM
Q-Dog
Dec 22, 2010 05:43 AM
sail414
May 25, 2009 10:06 AM
Daddy4life85
Apr 21, 2009 04:16 PM
