I知 seeing a clear type fluid , problems?
Old Nov 18, 2024 | 06:33 PM
  #31
Davhhr. Read post #19 again. The AC compressor is on in recirculation.
Old Nov 18, 2024 | 07:24 PM
  #32
Davhhr's Avatar
I dont run the AC so I doubt it's the compressor? however the recirc in cabin light is on, can't turn it off, it's either the "from the outside" button light or the "recirc in cabin" button light, but the AC is off. what about an exhaust leak where pipe is connected upfront could there be fluid coming from that?
Old Nov 18, 2024 | 07:55 PM
  #33
Last time.
When the selector is in recirculation mode, the AC Compressor IS ON. Regardless if the AC is on or off.
Old Nov 18, 2024 | 08:00 PM
  #34
Davhhr's Avatar
ah! well then would that be where the fluid is coming from the compressor? should I press the "from the outside" button and keep it on that to turn it off?
Old Nov 18, 2024 | 09:00 PM
  #35
Davhhr's Avatar
Last time.
Firemangeorge, why would there be small puddles of water if it's because the ac compressor is on??
Old Nov 19, 2024 | 04:50 AM
  #36
Condensation. All AC compressors produce condensation. Cars, home Hvacs. Ever noticed the drain pipes from a home AC dripping when it痴 running ? Same thing with cars. It was talked about earlier in this thread. Did you forget about the drain location on your car ?
Honestly. I have to ask. Is this your 1st car ? Haven稚 owned it long ? Your questions seem to be from someone who痴 never been around vehicles.
Old Nov 19, 2024 | 10:40 AM
  #37
Davhhr's Avatar
I know about condensation, just stressful trying to pin it down, but i'm not a car person, this is my 2nd car. This is a really helpful forum. thank you for your replies.
Old Nov 19, 2024 | 11:33 AM
  #38
On page 1 post 5 I posted ac drain photos for you to check
Old Nov 19, 2024 | 12:27 PM
  #39
If the AC compressor is running condensation is being produced in the drain pan. The drain pan dumps the condensate through the tube on the firewall.
It does not matter whether you use the washer or not; if the motor leaks it leaks all of the time.
Those are the only sources of clear fluid from under the hood
Old Nov 19, 2024 | 01:02 PM
  #40
Unless you have only water in the cooling system.
Waynejwj
Mar 17, 2024 05:30 PM
MJR1970
Maintenance and Upkeep
Feb 26, 2023 09:40 PM
Herbie
66
Jul 7, 2014 10:52 AM
bigjacksauto
Mods - Exterior
Jan 19, 2012 10:25 PM
Condition1
11
Aug 13, 2010 07:47 AM
