Ignition switch and codes
Absolutely. It cranked fine this morning, which is when it would normally stick on. But, it's gone a few days in between before, so I'll report back in a couple days when I would consider it "fixed".
Well, at this point I think it's fixed. 99% sure it was the starter. I think the cap on the solenoid spinning was shorting the incoming power supply with the crank signal wire, causing it to run on. I woulda suspected the starter earlier had it not been looking brand new.
JimmyJangle777
May 10, 2016 07:32 AM
