Improved Gas Mileage
Old Sep 9, 2014 | 02:14 PM
Snoopy's Avatar
Ouch, my feelings are really hurt with all the names I was called. But I do owe the 'red baron' an apology.....I mistakenly referred to him and it was supposed to be FBR, the OP, I should have referred to (who also made the claim of the incredible MPG increase after using fuel additives).
So, redbaron, if you see this, my apology (and by the way, I'm in Mesa, AZ not Mesa AR). To "FBR" it is now your turn to express your displeasure with my post ....or for that matter answer it.
Thanks db/sb...I was making some corrections and neglected to save them. So I needed to come back and do so. And I guess I am really confused now. Is the Flyingredbaron the same as FBR User? I see you have him quoted in your post above, but I don't see that person any longer. Are you confused also?
Old Sep 9, 2014 | 02:21 PM
db/sb's Avatar
I think FBR (shouldn't that be FRB?) said Mesa, AR not AB. If he does see this, I hope he doesn't think my pointing that out is sanctimonious, cynical, or pseudo intellectual.
Old Sep 9, 2014 | 03:44 PM
db/sb's Avatar
FBR_User and FlyingRedBaron are one and the same. Why he changed his user name I have no clue. What difference would it make if he's " unsubscribing" and "I'm (he's) taking my (his) discussions elsewhere"? I guess he doesn't want to leave the name here if he's not going to be here.
Old Sep 9, 2014 | 03:58 PM
Sundance's Avatar
Originally Posted by donbrew
"But my question still stands (to FlyingRedBaron): what do you do with the spray Sea Foam?"
You use it to clean the throttle body. It has a tube that bends, so you can spray inside and under the butterfly. Some people capture the tube under the rubber air tube to do a complete engine "fogging". It's all in the instructions: Homepage - Sea Foam Sales Company
Thanks Don, I had suspected it was something along those lines. And thanks for the link. No, you are not always the bad guy......
Old Sep 9, 2014 | 04:51 PM
FBR_user seems to be a catchall for the unjoined. Probably via proxy.
Old Sep 9, 2014 | 10:34 PM
  #26
And I didn't even get a chance to suggest he use the Search Tool. Anyways, he is gone. And this thread is clooooosed!!!
Silverfox
Nov 2, 2013 04:31 PM
Blue Dragon
May 28, 2009 08:10 AM
TkHHR
Jan 7, 2008 03:39 PM
greyghost
Dec 31, 2006 03:32 PM
