Injector replacement question
Old Apr 9, 2013 | 05:52 PM
oldracer's Avatar
Injector replacement: No programming needed....
I have been getting the P1174 code about immediately when starting out and after about 50 miles it becomes "stored" and CEL comes on. I have watched the engine parameters with AutoEnginuity on my laptop plugged into the ODB2 port. It tells me that fuel balance is bad and surprisingly seems to vary between cylinders 2 and 3.
So I ordered a set of Injectors and will replace them, probably on Saturday. If there are any lingering codes (P1174 has been the only one) I'll clear them.
My question is: does the car have to go back to the dealer to get the brain reflashed or most people that have replaced injectors found this unnecessary? I searched and found both situations listed here and also both on internet searches outside this forum. Thank you for the help.
Well since I had no replies as of this afternoon, after the new injectors arrived I went ahead and did the install. The middle two had some crud build up probably due to the gas we have in CA. I pulled the sleeves and cleaned around the o-rings and also in the seating area. The new injectors popped right in and I found there was little fuel pressure in the rail after the engine had cooled.
After putting everything back together, the engine started right up and did sputter a time or two and then settled right down. The engine ran smoother than before and in checking with my AutoEnginuity software, no codes or other issues.
fastsuv
Maintenance and Upkeep
17
Oct 21, 2013 08:15 PM
JAXFL_SS
13
May 21, 2013 02:15 PM
psxer989
May 13, 2011 09:10 PM
tahenke
Mar 6, 2008 10:49 PM
dnbguy86
Jul 27, 2006 12:26 PM
