2006 injector replacement
Old May 13, 2011 | 01:22 PM
psxer989's Avatar
I have a 2006 2.4 HHR. I need to replace my injectors and I saw the TSB stating GM 12625029 is the correct replacement. However, when I tried to install them they don't even come close to fitting. The end is too small and doesn't seat. Anyone replace their injectors and can you give me the corrected part number?
Thanks,
Larry
Old May 13, 2011 | 02:10 PM
ChevyMgr's Avatar
The part number is correct. They should fit with no problem.
Which end doesnt' fit? Engine or fuel rail? Are there O-rings on both ends? Are the tips dark blue?
Also you must get a reprogram after installing these or your check engine light will come back on.
Old May 13, 2011 | 02:37 PM
JoeR's Avatar
Maybe the cups that fit into the head came out with the original injectors? I've seen that happen many times.
Old May 13, 2011 | 03:26 PM
psxer989's Avatar
Cups? That must be it. I'll check again. I haven't seen cups on injector ports before. Thanks for the help.
Old May 13, 2011 | 05:20 PM
psxer989's Avatar
Injectors are in. It was the cups. Thanks for the help!
Larry
Old May 13, 2011 | 07:21 PM
ChevyMgr's Avatar
Nice, I didn't think of that.
Larry
Also nice...
Old May 13, 2011 | 09:10 PM
skyeglen's Avatar
psxer, can I ask how many miles on your '06 and why you are replacing the injectors?
lauriej
Mar 12, 2020 04:30 PM
anbishop1
Jul 19, 2016 12:01 PM
JAXFL_SS
13
May 21, 2013 02:15 PM
oldracer
Apr 9, 2013 05:52 PM
dseago
Feb 10, 2013 01:39 PM
