Inner tie rod part numbers
Old May 10, 2020 | 05:38 PM
tiapetra's Avatar
Originally Posted by donbrew
I would need a lot of evidence to be convinced there is any difference in FE1 FE3 parts. FE1 is called "soft ride" FE3 is called "Sport". I guess it is possible that the factory had different spring, shocks and sway bars;. if so that is the ONLY difference. After market vendors don't bother to make a difference generally.
FE1 was generally used for fleet (rental) cars and FE3 on "lot" (dealership) cars.
Cobalt is different; FE1 has stamped steel LCA and smaller front and rear sway bars and 4 lug wheels.
FE5 has a different knuckle/ball joint, springs and sway bar. I can't find any other differences. Not talking about steering gear, just suspension.
Rock Auto lists 3 different racks (part numbers) for each of the 3 different suspensions. So what is the difference if any?
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Old May 10, 2020 | 05:46 PM
I have no idea. but the bolt holes are in the same places. I can't image how the rack would affect ride. Maybe the FE3 is a little quicker that FE1. I doubt Harry Homeowner would ever notice a difference. Could be the paint or powder coat is different.
Old May 10, 2020 | 06:03 PM
I know the SS has a different steering ratio (turn to turn) than the other HHR models. Guess that tighter ratio is through different worm gearing in the SS rack.
Old May 10, 2020 | 06:38 PM
I use the FE3 in my 07 LS with FE1 suspension, no noticeable difference, every thing bolted right in , no wheel alignment required, I just had the disconnect the intermediate steering shaft to centre up the steering wheel
Old May 11, 2020 | 05:36 PM
tiapetra's Avatar
Thanks
Different ratios would make sense.
I know the auto makers don't make different parts unless they absolutely feel they must.
Old May 12, 2020 | 09:21 AM
Maybe the reason for different ratios is that some have 17 inch wheels most have 16 inch.
Old May 12, 2020 | 10:00 AM
Here you go. For some answers and reading pleasure. Scroll down to Chassis/Suspension
https://media.chevrolet.com/media/us...2009.tab1.html
BBHHR
14
Mar 22, 2019 04:50 PM
Wifes07LT
10
Aug 4, 2015 03:39 PM
Strikes4Days
14
Mar 26, 2015 05:33 PM
HHRLT
Jul 23, 2013 02:58 PM
