Installing aftermarket Remote Keyless Entry
Old Aug 15, 2017 | 09:21 PM
J W Davis's Avatar
That would be overkill by a factor of 100. 1/4 watt not 25 watt.
Like 1k at 1/4 watt would be just fine, this value is most common in applications like you are about to do.
Old Aug 15, 2017 | 09:47 PM
opensorce's Avatar
Oh I know it would be Overkill wattage wise... But I can get one locally and don't have to buy 100 that I'll never use... It would work, right?
Old Aug 16, 2017 | 08:35 AM
J W Davis's Avatar
Yes, of course I see your point.
Old Aug 16, 2017 | 09:12 AM
Voltage doesn't matter as much as physical size. It just needs to fit in the space.
Basically the PCB is 2 relays that connects one wire or the other to ground. You are adding a new switch to the circuit.
Here is my first foray into Visio:
Old Aug 16, 2017 | 10:11 AM
opensorce's Avatar
Attachment 45432
Does the PCB mean the RKE unit or...?
Old Aug 16, 2017 | 10:41 AM
  #26
yes
Old Aug 16, 2017 | 10:51 AM
  #27
opensorce's Avatar
yes
Gotcha! Thanks again. Picking up the resistor today or tomorrow. I'll let you guys know how it goes :-)
Old Aug 23, 2017 | 04:13 PM
  #28
opensorce's Avatar
Installing today... wish me luck!! I found a hot wire, I just need to find the white wire in C1 (the horizontal connector below the fuse panel) and a good ground and I should be golden...
I'll post again soon :-)
kodythekasper
Feb 4, 2015 04:43 PM
SlamminChevy12
Mods - Interior
Sep 18, 2012 08:49 AM
redrider
Apr 7, 2009 10:19 PM
vcalcaterra
Jun 6, 2007 12:02 PM
