Jacking points
Old May 7, 2016 | 02:56 PM
onelon's Avatar
Jacking points
I have an 07 HHR and it's time to work on its brakes. I was thinking of lifting the entire front and sitting it on 2 stands. However, I'm not sure where I can put the jack. There's this big piece of metal (part of the frame) that seems very tempting, but it's so far to the front that it makes me uncomfortable to use it. I uploaded a photo of it. Can anyone tell me if this is a good spot to use the jack?
Old May 7, 2016 | 03:01 PM
Welcome to the site, I use the big flat frame spot, just behind the bolt for the rear lower control arm for my jack stand and farther down under the middle of the front door you'll see a double layer of sub frame, that's where I jack the car up!
Be sure to block the rear tires!
If you don't have the parts yet, you may want to up grade to the larger SS non Brembo rotors, you just need the caliper brackets and the rotors.
Here's a link to Solman98's thread on that,
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
and they do fit under the 16 inch steelies!!
Old May 7, 2016 | 03:31 PM
Jack points are covered in the Owner Manual, there is a link in my sig.
Basically look at the rocker panels, you will see 2 arrows on each side, they point to a cutout in the rocker.
For jack stands I usually use the flat spots on the front sub-frame.
Old May 9, 2016 | 11:22 AM
onelon's Avatar
Thank you all for your replies and help. I was able to do this w/o the car falling on me or breaking anything lol
Old May 9, 2016 | 01:43 PM
Great job!
Goose
Dec 3, 2014 10:00 PM
fantomfreke
Sep 15, 2009 08:25 AM
hugheshhr
Nov 8, 2008 01:36 PM
Lee3333
Oct 25, 2007 11:26 AM
GER42
Maintenance and Upkeep
Oct 24, 2007 09:47 PM
