Lag isue ?
Old May 20, 2022 | 05:45 PM
Radco's Avatar
What has you experience been with the FixD? Someone gave me one, NIB. I don’t use it only because I already have something similar. As far as I can tell it has a real ELM327 chip, not one of those notorious clones. They try make you think you need to run their $ app, but it should run the free Torque Lite app fine, or any other app meant for an ELM327. Pretty sure I tried it and it worked.
I have on;y used the FixD twice just to try it
Worked OK but has its limits, And they say you can leave it plugged it 24/7 and if a code pops up send it to your phone !
Yo can not rest ABS
And the Paid app ? I do not have it and think for better detail on codes a real reader is best. But for checking your car or one your looking to buy has its value.
Got mine on a sale promo for $9.95 and got one for 1 cent ! They sit in the glove box till I want to check anything !
Would I pay the 60$ for it ? NOPE use to for a real full use scanner
Old May 20, 2022 | 10:32 PM
Torque Lite does everything you need. If you are clueless anything that can change things can be dangerous. There are only 4 things reading ABS could tell you, mainly which wheel is the problem then if it is open or short, anybody with a bit of research can do that without a reader. Airbag system should not be messed with by people that have to ask why.
For that matter there are quite a few other softwares out there, thing is OBD2 only has a limited number of nodes and Torque Lite reads them all. The problem with ANY reader is the operator needs to know what the information actually MEANS, not what is "says". I have used ELM327 devices that me less than $10 that did everything I needed, I used it to interface to my laptop running pretty sophisticated software. You still need to use GoOgle don't ever trust anything the reader suggests without verification. P0017 is a case in point, I wonder how many people have wasted money on crankshaft sensors..
Old May 21, 2022 | 06:12 PM
Radco's Avatar
LOL Yes I am clueless and would not change any codes . I just want to keep a mechanic honest lol SO just a good reader is all I need .
UPDATE #2
His HHR Died does not accelerate . So Off to the shop And I was right the magic cure did not work :O
My guess fuel pump so will see what the mechanic says ! If I am right I win a cookie lol
Old Aug 15, 2022 | 07:55 AM
DirtyhandsRyan's Avatar
UPDATE #2
What did you find out from the mechanic?
ColonelStinkmeaner
Oct 19, 2021 05:12 AM
emstess
Oct 10, 2021 12:23 PM
drspock
Feb 11, 2018 11:44 AM
Jfidelh
Oct 9, 2012 06:14 AM
cwalker
May 18, 2008 01:23 PM
