Lazy shoulder harness belt
Old Apr 4, 2017 | 08:10 AM
Cat Man HHR's Avatar
The driver harness was slow to retract so I used this on it
https://www.lowes.com/pd/DuPont-11-o...ricant/1059839
Pulled the belt all the way out and lightly sprayed it where it enters the plastic molding, continued to spray the belt as it retracted in. Sprayed the buckle/loop also.
It does have a kind of sweet odor to it but it slowly goes away in a few days. The belt retracts all the time and doesn't hang up where it get's caught in the door jamb.
Old Apr 4, 2017 | 08:39 AM
solman98's Avatar
Not sure I'd want to spray any type of lubricant on the seat belt mechanism. Wouldn't want it to slip when you really needed it.
Old Apr 4, 2017 | 09:10 AM
This explains how the seat belt works
Extend and Retract - How Seatbelts Work | HowStuffWorks
Your applying it to the material so it will side more easily.
Old Apr 4, 2017 | 09:47 AM
Mine shows no longer available at Lowes!
https://m.lowes.com/pd/DuPont-11-oz-...ricant/1059839
Old Apr 4, 2017 | 02:31 PM
Blue I found mine at Ace Hardware. I used Lowes as an example of the product.
Old Apr 4, 2017 | 02:40 PM
Oh, great thanks. Now does that leave any marks on your clothing?
Old Apr 5, 2017 | 11:35 PM
Casa Del Gatos's Avatar
Man, that is a really good question. I would sure think so, if the lube is sprayed on the webbing material itself. I would expect grease stains on my shirts.
I've been wrong before though.
Old Apr 10, 2017 | 07:36 PM
Don06's Avatar
It's a dry teflon spray so it shouldn't leave any residue on your clothing. I use the WD40 Specialist dry lube on the belts and door gaskets and frames to keep them from freezing together.
Old Jan 10, 2022 | 08:14 AM
Mike's 2007's Avatar
WELL, did the spray help on the LAZY seatbelt return? I have to spoon-feed mine back in every time. Thats what i was wondering about. Is it like buying used brake shoes? Buy new belt and retractor?
Old Jan 10, 2022 | 08:21 AM
New. There is an explosive pellet in it that locks it on impact. Junkyards may not sell them, don't know for sure.
