Light sensor replacement
Old Jan 2, 2026 | 01:11 PM
desertrat's Avatar
The switch was set to AUTO. The scanner showed 5 volts present, and when I manually decreased the voltage (with scanner) like the photocell normally would in daylight, the dash brightened as it should. This shows me that the BCM is working OK and the sensor (photocell) is defective.
Old Jan 2, 2026 | 01:35 PM
OK, have fun.
Old Jan 2, 2026 | 05:03 PM
I found this in the archives
https://www.chevyhhr.net/forums/how-...-sensor-62500/
And this
https://www.rockauto.com/en/parts/ac...p+sensor,17059
So it has been a problem for somebody’s HHR
Old Feb 1, 2026 | 07:51 AM
desertrat's Avatar
I finally took the dash apart as best I could, and found out that the light sensor wiring was never plugged in from the factory. It was coiled up just laying there, so I managed to get it connected and now the dash lights work as they should. I am making another rpost as to how I loosened up the top dash pad.
Old Feb 1, 2026 | 11:43 AM
Must have been assembled on a Friday! Glad you got it figured out!
Allen P
May 26, 2021 08:16 AM
'Lil Red Wagon
Apr 8, 2013 04:56 PM
scoutmstr
Maintenance and Upkeep
Nov 20, 2012 10:08 AM
thegodfather
Mar 14, 2011 05:10 AM
Hotrodbob
Nov 24, 2010 11:16 AM
