Lighter/power plug
Lighter/power plug
My new to me HHR has the power plug on the console, with a lighter installed in it. From the element I could tell it had been used. Now, the circuit blows the fuse, even with the lighter removed. Any ideas?
If it blows with the element removed, then there is a short down there in the bottom (it's broken). If you want to use a cig lighter go purchase one for about $5 from a GM dealer and install it (fairly simple). Unless your car came with the "smoker package" I don't remember the code, it came equipped with a "power outlet" which will not work long with a lighter element. The same fuse powers the OBDII port, by the way.
weekendwarrior
01-20-2011 08:35 PM
