Lights are on but not cranking
Old Jan 28, 2017 | 04:42 PM
John Leland Fogleman's Avatar
Car lights & interior lights, rado all came on when I turned the key, but it wouldn't crank. Jumped it (left charging for 5 minutes) No luck. Ckd the fuses,all clean. I'm no mechanic, just cking off the obvious? Can anyone help
Old Jan 28, 2017 | 05:18 PM
Wouldn't it be obvious to check the starter, alternator and battery?
5 minutes won't charge anything, if it started with a jump that tells us that either the battery is not supplying enough power or the starter is demanding more than the battery has.
Old Jan 28, 2017 | 05:45 PM
Hi John, to the forums!!
Like donbrew said above, your charging and/or starting systems are suspect.
In addition to fuses, there are also relays in the underhood fusebox that are associated with these systems.
It may be helpful to list the year, miles, engine, trans, and trim level of your vehicle. It may also have something to do with clutch pedal position sensor or neutral safety in the automatic's shifter.
Old Jan 28, 2017 | 07:52 PM
And how old is the battery?
Old Jan 28, 2017 | 08:38 PM
Welcome to the site! X3 dead battery!
foolmoon_design
Sep 10, 2012 01:10 PM
Silver11
Sep 29, 2011 02:42 PM
Milander
Jul 2, 2009 01:43 PM
volcycle
Oct 12, 2008 08:34 PM
TXLeXTC
Feb 25, 2006 03:49 PM
