Loose axle in transmission
Old Mar 21, 2011 | 07:41 PM
speedemon's Avatar
Hey all. I've been chasing the famous clunking noise in the front of my '06 for over a year now. My steering column has been changed, the intermediate shaft, stabilizer links. I've checked all my bushings, shocks...everything and found nothing until the other night. I was checking yet again and I grabbed the passenger side axle to move myself around under the car and it's kind of loose where it goes into the transmission. I know that there is generally a bit of play there, but this is quite a bit. I can wiggle it up and down and when I do, I get a light knocking noise that I'm pretty sure is my clunking when I drive.
Has anyone experienced this before? Any ideas what the problem may be? Am I looking at replacing an axle or having the transmission torn apart?
Thanks,
Speedy
Old Mar 21, 2011 | 08:15 PM
I'd think its either a failure of the inner CV joint or excessive wear on the splines at the transmission end of the halfshaft. Its going to be hard to tell exactly without pulling the halfshaft to check the splines and CV joint off the car. Did you notice any leakage of grease from the CV boot or wetness on the transmission case?
Old Mar 22, 2011 | 07:39 PM
speedemon's Avatar
No, there's no leakage or wetness at all.
Old Mar 22, 2011 | 09:40 PM
Well I hate to say it but you may be faced with pulling the half shaft to get a clear picture of the failure mode. I'd bet you're dealing with a failing inner CV joint, but you might want to have a tech check it out for their opinion.
Old Mar 24, 2011 | 11:53 AM
speedemon's Avatar
Thanks. I'll have the dealer check it out when it goes in for the notice I got about power steering failures on them.
Old Mar 24, 2011 | 07:06 PM
T 20's Avatar
Question Power steering notice
speedemon,
Was curious of what year model you have, because I never received a notice about the power steering... I have a '10 model; maybe it was 'fixed' on the newer models???
Oops! I see now that you have an '06... Duh.
Mo
Old Mar 24, 2011 | 07:30 PM
The notice only went out in Canada, the US is still waiting.
Old Mar 31, 2011 | 06:43 AM
speedemon's Avatar
Originally Posted by T 20
speedemon,
Mo
The notice says for 2006 models, nothing about any other years.
bowtieboy68
Maintenance and Upkeep
51
Feb 20, 2011 01:44 PM
eaglefreak138
Jul 15, 2010 05:47 PM
Cokeybill
2.0L Performance Tech
11
Aug 8, 2009 11:02 PM
Lee3333
Feb 6, 2009 08:44 PM
adamlowery
Jan 17, 2006 12:36 PM
