Visors loose
Visors loose
Has anybody had their window visors get a little droo py? I do admit to keeping a few papers on top, but nothing too heavy. So now my visors are not staying up tight against the roof. I have not looked closely at them yet, but was wondering if there is a way to tighten them? Is it friction or a spring that holds them up? (On older cars, there is a screw holding it to an arm and if you tighten the screw it increases the tension.)
Thanks for any advise. Tomorrow it is supposed to warm up so I should be able to tolerate sitting in the car and pulling them apart without running the engine to keep the heat on and spending a fortune in gas.
Problem is that I am out of warranty now. I have to go back next week because right before it ended they diagnosed a knock as a bad steering column. They changed it last Thursday, and it was quiet until yesterday. Also, they didnt center the steering wheel. I will ask them about the visor but it may be too late.
