Loose Wire Identification Question
Old Nov 12, 2017 | 02:37 PM
NoHPbutalotofheritage's Avatar
Can anyone help me to identify this loose wire I noticed hanging from the wiring harness above the starter? Thanks
Old Nov 12, 2017 | 03:50 PM
What doesn't work/ is there a CEL?
What color is the stripe? It looks like black w/yellow.
If it is black w/white the car probably doesn't do anything. That is the main ground that should be attached to the transmission with at least one other wire that goes to the radiator support.
Old Nov 12, 2017 | 04:53 PM
I'm with Don. Looks like a ground wire with the loop end broken off. Search around in that area. You may find the remnant of the broken loop under a bolt head.
Old Nov 12, 2017 | 05:18 PM
Yes look at the ground wire location on the transmission housing down to the right of the oil filter cap.
Old Nov 12, 2017 | 07:55 PM
Could be the reason your HHR was very sick!
US66HHR
Apr 5, 2014 06:51 PM
Krash Kadillak
Dec 5, 2010 03:06 PM
gmdealerguy
Oct 6, 2010 10:36 PM
Lubepro
Aug 13, 2010 11:45 AM
adamlowery
Jan 17, 2006 12:36 PM
