losing brake fluid
Old Dec 27, 2013 | 04:16 PM
Or, if you're really brave, disconnect the master cylinder to see if the rear seal is leaking into the vacuum booster.
But it's not going to be easy or fun.
Old May 12, 2015 | 08:01 AM
PWRWGN's Avatar
Loose bleeder
My fluid loss turned out to be a loose bleeder in the rear. It was only loosing fluid under firm breaking which I try to avoid in my day to day driving so I was not loosing a lot of fluid. On the bright side my brake fluid has been flushed
Old May 12, 2015 | 08:27 AM
Did that take two years to find? Dane
Old May 14, 2015 | 05:38 PM
PWRWGN's Avatar
Thankfully no, but I found this thread again and thought I'd give everyone a good laugh
Old May 15, 2015 | 06:15 AM
I've gone to follow up with threads and couldn't find them!
Thanks for the follow up , and conformation of your findings!
My issue was the cold and the master cylinder reservoir.
glenngeb
Feb 4, 2019 03:56 PM
Rjj
Oct 22, 2017 08:56 AM
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
hozer
12
Mar 16, 2014 07:06 AM
fastsuv
Feb 22, 2013 10:36 PM
