Low beam rt hand side not working
I have read all the post on head lamp and I have checked the fuse I have checked the wiring I have changed the bulb. But can't seem to get power to the low beam on the passenger side.. anyone come up with this problem. I have also try ed jumping a hot wire at the fuse and no thing
So. You checked and there was no power to the fuse ? That is the reason that you jumped a hot wire to the fuse ?
Next step would be to check the ground wire. It won't light up if it's not grounded.
Before replacing parts, it's always best to test for power and ground continuity. A good test light and multi-meter will save a lot of time and money.
