low voltage
Old Jul 20, 2024 | 04:10 PM
Ericd190's Avatar
low voltage
Hello ,I'm new here but i have questions about my 2006 hhr?
I had to take the power box under the hood out to work on the car and now I'm having electrical problems.
First couldn't get power to ecm from the box, now I've got starter to turn over but it say's low engine voltage? I can't get it to start? What is up with this car?
So many things that it could be but trouble shooting isn't easy? Anyone out there know what I need to fix or replace? I've have been with this car from day one as it was my mothers car
from the dealer and now it's my car. I just need for it to run. My other car is a work truck that doesn't get gas mileage at all.
Old Jul 20, 2024 | 05:00 PM
Welcome to the site, first off tighten the 4 bolts in the fuse box and the 13mm nut under the red hood
Red hood. ^. ^. ^ 7 mm head bolts , tighten them gorilla tight!
Old Jul 20, 2024 | 05:19 PM
When you put the box back together there are all of those connections that need to click in, the bolts need to be tightened until you hear a couple of clicks, way past "I was afraid to strip them".
This happens weekly around here.
Old Jul 22, 2024 | 09:06 PM
Ericd190's Avatar
I seem to have no power to the OBD plug?? So I'm still having connection problems in the box.
Not sure why every thing is tight and all the other relays and fuses have power. But the ECM fuse doesn't have power??
Not sure why that is when the starter is working ? all the fuses are good I pulled and checked them.
Old Jul 23, 2024 | 07:53 AM
"Tight" is not enough!!!!!!!!! The fuse for the cig lighter powers the OBD plug #29 under hood.
Remember all of those connections under the fuse box? All of them need to go "home". You need to hear a a few clicks.
Old Jul 27, 2024 | 12:23 AM
Ericd190's Avatar
So I went back and retighten the bolts on the underwood box and I finally got it all to work thanks for the help now I need to get the A/C recharged and working
Old Jul 27, 2024 | 07:16 AM
Glad to see you got it running again!! Enjoy the ride!!
Carlos77
Jul 24, 2021 05:45 PM
Delton
Jul 29, 2020 05:11 PM
Bpopilek
Oct 6, 2019 03:23 PM
cannuck
Jul 24, 2016 07:13 PM
HHR_Issues
Sep 19, 2008 02:03 PM
