Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Well, darn. All of a sudden, my rear, driver's side window doesn't work. Will not go up or down, from either switch. Happy that it is stuck "up", I am. Assuming it is either the drive motor, or the wiring to the door. Got any hints or tricks?
There is some logic in the dppr switch; the master switch commands the door switch. so it is possible it's the door switch that is bad. I would test the motor with 12 V and ground to narrow it down.
