Many problems, timing chain
Old Jun 1, 2017 | 04:09 PM
Since you want it so bad I will move it to different section.
This is the first mention of the chains having been changed TWICE.
P0016 & P0017 men that either the chain is not aligned correctly (i.e. stretched or a tooth off) or the sensors reporting the fact are wrong.
If you want other examples you could put "p0016" or "p0017" into the search form at the top of the page. Hint: change "Threads" to "All".
At the risk of being redundant; see the link in my sig re: "I got a check engine light".
Old Jun 1, 2017 | 04:17 PM
I agree it's the timing chain causing some vibrations, it's off one tooth causing problems.
I also believe you would be wise to replace both LCA's and the wheel bearing hubs.
Get the proper cast aluminum LCA's
Old Jun 1, 2017 | 04:27 PM
Ah, see post 2.
The timing chain is off one tooth! Trust me it will cause a vibration
Old Jun 3, 2017 | 12:18 AM
He's just messing with you guys.
Since his questions have all been answered. Lets close the thread.
Banana hands
Apr 17, 2014 04:49 PM
dnutbrown
Aug 13, 2012 10:48 AM
TEKNOnaut
Jul 13, 2012 06:56 AM
codered3232
22
Mar 6, 2012 09:01 AM
wagoneer
Apr 9, 2009 11:44 PM
