menu button on steering wheel
Ok sno white I jumped the ground and everything will work, so now I know I have a ground problem, is this in the clock spring, I checked the dash lights dimmer and it was not effected by this, so info button, horn and cruise button light was affected, can this ground problem be fixed or it requires a new clock spring,or for a quick fix add a jumper ground.
If the tech took the steering wheel off to do the recall, he could have broken the clockspring. Or he could have disturbed the ground on the chassis side of the clockspring.
Good news: easy to DIY. Bad news: expensive part. Look for the chassis side ground and hope.
Very good point. When working on wiring issues always check when human hands touched last.
See last sentence in post #7 if you truly believe this had to do with the recent ignition switch work on your vehicle.
You will have to take the plastic shroud away from the steering column in front of the steering wheel to inspect the clock spring connection. It is possible the connector was jarred when the switch work was done. You could also put a temporary ground at the clock spring input to see what works. If you ground that point and things still don't work it would be the clock spring.
A thread of mine that might help you to gain access is:
https://www.chevyhhr.net/forums/how-...ts-pics-37992/
dlmhhr
Mods - Interior
Mar 23, 2011 12:52 AM
