Message Gate ajar
Old Apr 17, 2019 | 07:07 PM
I find it difficult to believe that 1 wire in the harness got itself broken.
You are looking at the plug wrong.
in post #18 the pic is of the PLUG pins facing you.
You are looking for the PINK/BLACK wire on pin #55
I would check for continuity of the PINK/BLACK wire from the LATCH (not the touch pad) to the BCM. And check with a multimeter if the switch in the LATCH is working. The entire wiring diagram is posted earlier, look at it again. Note there is a switch in the latch and in the touchpad.
Old Apr 17, 2019 | 08:21 PM
John Goelz's Avatar
OK. I will have to start back at the rear and work forward. Thank you for your assistance!!!!
aztrooper
Apr 24, 2015 06:23 PM
angleplug
Nov 17, 2012 12:05 PM
mo650chopper
Jun 11, 2009 08:24 PM
SIHHR
Sep 9, 2006 11:56 PM
May 5, 2006 11:42 AM
