Multiple issues - 2011 HHR LT2 - 101k
Old Oct 28, 2018 | 09:46 AM
Sheila Cheasbro's Avatar
Hello! I'm a newbie to this forum, although not new to vehicle repair.
I have a 2011 HHR LT2, otherwise known as the money pit.
Here are the issues I'm currently having:
1) Tire Low Add Air light continously illuminated on DIC and instrument panel, even though actual pressure levels are on target. New pressure sensors were installed/calibrated less than 6,000 miles ago when brand new tires of the correct size were installed.
2) Service ESC message on DIC continuously
3) Brake Fluid message on DIC as well as red BRAKE warning light illuminated on instrumENT panel.
4) Traction control light illuminated on instrument panel
5) Two headlights while on Brights, but only one headlight on dim. Have replaced bulbs with no change.
6) Squealing/screetching noise when driver's window is rolled up or down. Dealership replace entire molding kit on drivers's door along with window channel kit. Noise stopped for a while and then came back as bad as ever.
7) Occasional dry start - like oil is not reaching the top of the motor in time when first started. Dealership has "looked" at the car for this but said they couldn't find anything and couldn't justify tearing into the engine for an intermittent issue.
8) Driver's side interior door handle fell off in my hand
9) When car is on accessory mode with radio on, battery will deplete within 15 minutes. 2 new batteries installed, alternator and charging system test perfectly.
10. Emblem on rear of tailgate - plastic "cover" fell off and now decal is flaking off. This began at 55,000 miles
11. First wheel bearing fail at 50,000 miles. PS
12. Same wheel bearing failed again at 70,000 miles.
13. DS wheel bearing failed at 55,000 miles
14. Same wheel bearing failed again at 70,000 miles
15. Replaced sway bar links, tie rods, wheel bearings, brake pads, rotors, A-Arm/ball joints (PS) at 92,000 miles
16. A-Arm and ball joints need replaced on driver's side now
17. Steering pulls to the left even after having an alignment done professionally.
Anyone else have these issues and or suggestions of how to fix them? I will never ever buy another HHR again.
Old Oct 28, 2018 | 11:27 AM
Anybody thought to scan for Cxxxx codes? Takes a ABS capable scantool.
1 Before and after?
1,2,3,4 are related. Electrical problem, or the wheel bearings weren't installed correctly.
5 fuses; I bet the Right one works on low beam, but only the Left one works as DRL; That would mean the Left Low Beam fuse is blown.
6 nobody ever heard of lube?
7. what? How do you know?
8. that's why there is a cheap repair kit.
9. sorry, that's life.
10. whoever fixed it the first time blew it.
11-14 bearings fail, especially the really cheap ones,
15. typical
16 typical
17. related to 16
Old Oct 28, 2018 | 01:53 PM
I would add #9, don't leave the key in accessory. The radio will play for 10 mins or until driver door is opened, with the key off. Maybe fewer systems drawing power with key off.
Some things are cheap on these cars. They were not high end cars. On top of that, they were produced when the General was having severe financial problems. Even high end cars have cheap plastic parts on them.
Old Oct 29, 2018 | 12:09 AM
x2 what they said ... and not everything lasts forever.
Old Oct 29, 2018 | 09:21 AM
From 92,000 to 110,000 is not along life for LCA’s , perhaps it’s the replacement parts, there are known problems
Old Oct 30, 2018 | 11:25 AM
Ohiocruiser's Avatar
Doesn't look like you want to do anything to that car. Just venting I guess. Get rid of it, and buy something else.
Old Oct 30, 2018 | 01:39 PM
I would like to know about the "dry start" thing. What are the indicators etc? Never heard of it; maybe talking about timing chain rattle? Different cause, could be related to traction light.
Old Oct 30, 2018 | 04:44 PM
Silverfox's Avatar
Sheila,
In regards to #9
Read my latest post on fuse #24
Silverfox
Old Oct 31, 2018 | 09:55 PM
guppy's Avatar
Bad TPMS sensor, buy an AC delco next time. sometimes the tire guy whacks it installing the tire, watch them.
Electronic Stability Control , pull engine codes
Inspect pigtail at bulb
All of our door handles have broken off, someone makes them out of metal now.
Yup, mine too.I cleane doff the rest of the gold paint, painted the back side red and glued it back on
Buy a name brand wheel bearing such as timken
Replace LCA bushings, both sides
Old Oct 31, 2018 | 10:06 PM
Closed - never came back - rant is over.
Pewkerdad
Dec 21, 2015 09:29 PM
Mowgli
Apr 11, 2011 10:41 AM
jrsharp21
Mar 16, 2011 09:22 PM
roofer1976
Jan 21, 2009 04:02 PM
