My HHR is hazard to road safety!
Old Jul 7, 2007 | 11:05 PM
TomsHHR's Avatar
I found a couple of "• Reduced Engine Power Active, electronic throttle control" on a GM site, you may want to ask your service dept about this.
Old Jul 7, 2007 | 11:11 PM
captain howdy's Avatar
Originally Posted by Snoopy
I'm not "buying" the loose fuse theory.
I have not, on purpose, touched any of my fuses since the day of delivery. I'm waiting to see when a problem does occur. So far, 15 months, nothing related to lack of electrical flow.
Same here. And I'm at over 15 months.
Old Jul 7, 2007 | 11:20 PM
Harpozep's Avatar
It has not happened to us, but now I worry.
Is this a something in all car computers now, that they would cripple the car's power to save some part of the car and perhaps place one in mortal danger unexpectedly? I know all mortal danger is unexpected when you are driving and things move so quickly, but to have the car itself compromise your safety in a highway situation, seems untenable.
Maybe I'm just overreacting and the situation is really no different than having a high speed blowout or somesuch.
But to have a code come up and do this without letting on as to why is even stranger and potential;ly more perilous since , well, you do not know what caused it while you would know what a blow out is all about.
Old Jul 8, 2007 | 01:21 AM
Snoopy's Avatar
Originally Posted by Black Beauty
I don`t understand this Snoopy, you would give advice to others about oil, tires, etc; and then come out against something that could actually be a problem, even go so far as to say, you "have not, on purpose, touched any fuses...waiting for a problem to occur".
Very strange position. But HHR`s are expendable and easily replaced..
It's not advise, it's an opinion. You don't like it, skip my comment (similar to advise you have given other members) and go on.
Old Jul 8, 2007 | 12:41 PM
nfboy's Avatar
When I first got my HHR I did check the fuses under the hood and they all seemed to be seated just fine. I never ever checked the ones on the passenger side inside. I have had 12 enjoyable months of ownership with no mechanical or electrical issues whatsoever. All I have had done were the rotors ground down, a TSB radio re-flash for reception which may not have even been needed and the armrest TSB fix.
Old Jul 8, 2007 | 05:58 PM
Black Beauty's Avatar
I think the problem with conversing by keypad is the there`s no way to know what`s advice and what`s opinion, so sometimes opinions seem like advice.
But having an opinion that you would wait for a incident prior to attempting to prevent it, is what I was referring to, of course another thread about this a year from now (from you) will be a fresh discussion...
Old Jul 8, 2007 | 06:17 PM
dadd75's Avatar
Red face
I did write about my problems with "reduced engine power" on other threads.
I have a 07 1LT, 2.2. I kept getting the above message, took car in three times and they made changes, but it still happened. Finally they found out I had corroded wires behind the kick-plate on the drivers side. Of course, they don't tell me if this will continue to happen, car is only 3 months old.
Old Jul 8, 2007 | 06:20 PM
So maybe it`s not the fuses, but IMHO, check them anyway.
Old Jul 8, 2007 | 06:28 PM
Alzonie's Avatar
Wonder if there might be some kind of material you could safely make a pad out of, to put under the fuse box lid that puts just a bit of pressure on the fuses. Something that would keep them from working loose, or at least some of them!
Old Jul 8, 2007 | 07:30 PM
I don`t think they`re working themselves loose, I don`t think they were ever seated right from the factory.
If you put something in or around your fuses, you may compromise the design, ie; let moisture gather, create a heat source, impede air flow (if any), who the heck knows what could be affected.
