Is my water pump bad???
Old Jun 11, 2012 | 10:52 PM
oneton's Avatar
I just keep the digital temp reading on the DIC all the time. Why look a the mileage and that never right air temp. If I need the trip I just set and go back to temp.
Old Jun 12, 2012 | 07:02 AM
kornellred's Avatar
The needle indicator in the analog temperature gauge in the HHR moves very little after operating temperature is reached. From 180 to 220 degrees, movement is barely perceptible. My own HHR has never exceeded the normal operating temperature range, so I don't know if the analog gauge needle moves toward the upper end of the scale when the engine gets too hot. Since engine temperature is vital information, I always drive with the DIC displaying coolant temperature.
Old Jun 12, 2012 | 09:34 AM
Well I guess I'm lucky to have the RPD unit on my SS. It displays the coolant temp in digital.
Old Jun 12, 2012 | 05:12 PM
Laco's Avatar
Originally Posted by the_shmoo
Seems pretty normal, my HHR runs at 195 and cycles between 180 and 215 (before cooling fan kicks in). Higher temps normal while idling during hot weather.
My 2007 runs at the above temps too.
beltrunner
May 5, 2015 09:28 AM
donbrew
Jan 21, 2013 08:00 PM
wagoneer
Jan 12, 2010 11:17 AM
masterchief1112
Oct 19, 2009 03:47 AM
